AC18 to AC21 Stairs importing as objects
Hi guys,
I am transitioning from AC18 to AC21, when i open a project which was completed in ac18 in ac21, my stairs are imported into ac21 as an object and no longer editable as a stair, only an object, so i lose the stair selection settings which i need?
Cain
3 Replies 3
It seems you can make cosmetic changes but not actually alter the structure of the stair.
http://archicad-talk.graphisoft.com/viewtopic.php?p=271434
My only suggestion is to re-model the stair in 21.
Thanks, I thought that might be only solution
alemanda
I think stairmaker should have kept for at least 2 or 3 versions from version 21.
In every on-going project we migrate there is for sure a stair to be modified ... in this case we have to re-model in AC21 from scratch ... it's time consuming.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
