Aaron Bourgoin
AC22 Library Update
AC22 is telling me that my Library is not up to date. The download site lists a Library release dated January 2019.
Is there a new Library update with a wrong date or is it a glitch in the check for updates system?
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
1 Solution
Aaron wrote:
David,
mine says 3003.2. that seems strange. we're working under AC build 6001.
Updating the Archicad build does not update the library.
The library update is a separate update.
Go to post
5 Replies 5
David Maudlin
Aaron:
On my installation, under License Information, the Library Build Number is 4030.57, and the Check for Updates... web link tells me my library is up to date. What does your License Information say?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Aaron Bourgoin
David,
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
The problem happens when You place the additional finishes package with its own xml file... the update page inspects all xml files that have the "update" info.... and in most cases the wrong xml is taken into account..and causes error...
(it took me some tim to figure it out - thankfully I had one computer where I did not put thos shaders into normal Archicad Lib)
Piotr
Aaron Bourgoin
Thanks Piotr, that would explain it.
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Aaron wrote:
David,
