hevi
Ace
AC26 INT Cabinet Corner Object
EDIT : This was just me being embarrassingly unobservant.
Something seems to be off with the cabinet corner objects in AC26 so that the shape representation does not correspond to the segment settings. In the example below - the setting is set to one segment = no shelf yet it is represented with a shelf = two segments.
1 Solution
David Maudlin
thesleepofreason:
Go to Kitchen Cabinet Settings > Segment Details... > Number of Inner Segments and set it to 1.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
2 Replies 2
David Maudlin
thesleepofreason:
hevi
Ace
Had some nagging recollection of such a setting. Too tired being blind - thanks for setting me straight!
Post should be moved to design forum.
