ARCHICAD Libraries
I recently switched to the FR version due to work commitments and unfortunately, could not keep my International version which is in EN.
I forgot to save the AV EN version libraries.
I need to open some of the files I did in the EN version, in the FR AC 23 version I am now using. However, of course, I need to import the missing EN library .
Anyone able to send me the EN library 22 and 23 plus older versions please ? Perhaps a dropbox link for eg?
I am missing the AC .icf files it seems.
Thanks
SW
You can download all ARCHICAD 23 versions from the following web page:
https://www.graphisoft.com/downloads/languages/
You may have to Sign In with your GRAPHISOFT ID, and also create a GSID if you don't have one yet.
Thanks LASZLO :
