Accessories not seen in the loaded libraries
Hello!
I do not find the wall and other accessories.
I tried to reinstall goodies/ Archicad, however, the issue persists.
Please respond.
Thanks in anticipation.
NS
Archicad20
Windows10
1 REPLY 1
You must load the accessories library using Library Manager. After the Accessories goodie has been installed, you will find the Accessories Library as a sibling library to the ARCHICAD Library in your program folder.
