mmbrajohan
Adding Fills to 2D GDL Objects
Hi guys and gals.
I'm trying to add a fill to an object.
It's a circle with text inside.
I attached the rest of the coding as well.
Here is the code:
! Name : a1 ceiling recessed downlight.gsm
! Date : 05 June 2014
! Version : 16.00
! Written by ArchiCAD
mul2 A/0.239992, B/0.241445
add2 201.1519424713, 193.3597164888
pen penAttribute_1
hotspot2 -201.0319463291, -193.2389938163
pen penAttribute_2
line_property 0
line2 -200.911950187, -193.2389937948, -200.9168108738, -193.273005308
line2 -200.9168108738, -193.273005308, -200.9309991505, -193.3042614107
line2 -200.9309991505, -193.3042614107, -200.9533655673, -193.3302299193
line2 -200.9533655673, -193.3302299193, -200.98209813, -193.3488070198
line2 -200.98209813, -193.3488070198, -201.0148690973, -193.3584877058
line2 -201.0148690973, -193.3584877058, -201.0490235605, -193.3584877059
line2 -201.0490235605, -193.3584877059, -201.0817945279, -193.34880702
line2 -201.0817945279, -193.34880702, -201.1105270907, -193.3302299196
line2 -201.1105270907, -193.3302299196, -201.1328935075, -193.3042614111
line2 -201.1328935075, -193.3042614111, -201.1470817843, -193.2730053085
line2 -201.1470817843, -193.2730053085, -201.1519424713, -193.2389937953
line2 -201.1519424713, -193.2389937953, -201.1470817845, -193.2049822821
line2 -201.1470817845, -193.2049822821, -201.1328935078, -193.1737261794
line2 -201.1328935078, -193.1737261794, -201.110527091, -193.1477576707
line2 -201.110527091, -193.1477576707, -201.0817945283, -193.1291805703
line2 -201.0817945283, -193.1291805703, -201.049023561, -193.1194998842
line2 -201.049023561, -193.1194998842, -201.0148690978, -193.1194998842
line2 -201.0148690978, -193.1194998842, -200.9820981304, -193.1291805701
line2 -200.9820981304, -193.1291805701, -200.9533655676, -193.1477576704
line2 -200.9533655676, -193.1477576704, -200.9309991508, -193.173726179
line2 -200.9309991508, -193.173726179, -200.916810874, -193.2049822816
line2 -200.916810874, -193.2049822816, -200.911950187, -193.2389937948
define style{2} "AC_STYLE_1" "Arial", 0.1, 0
define style{2} "AC_STYLE_2" "Arial", 0.075, 0
paragraph "AC_PRG_169" 2, 0, 0, 0, 1
set style "AC_STYLE_1"
"A"
set style "AC_STYLE_2"
"1"
endparagraph
textblock "AC_TEXTBLOCK_169" 0.15, 1, 0, 1, 1, 0,
"AC_PRG_169"
AC 23
Ryzen 5 3600
32GB 2400MHz RAM
NVidia RTX 2070 Super
512GB NVME
2 Replies 2
It looks like you have drawn your object in 2D and then selected it and saved it as an object.
That is the best method for simple objects and saves you from learning to much GDL.
Do the same thing but actually draw a filled polygon (magic wand to a circle with 'best fit' in the magic wand settings.
Add you text and anything else you need and then select that and save as an object.
It should create a script with the correct POLY command.
Erich
While not strictly necessary, it is good practice to create objects in the floor plan at or near 0,0. This will make the GDL code much clearer should you decide to start learning at some point or if someone else needs to tweak an object.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
