‎2006-08-2107:15 PM - last edited on ‎2023-05-2412:07 PM by Rubia Torres
‎2006-08-2107:15 PM
I just downloaded the Anderson door & window library from Graphisoft. The problem is that the FWH doors aren't labeled the same way as they are in the Product Guide. eg. They show a FWH 6068 ASR that in the book would be an ASL. The library also only shows them hinged on the outside when an ASR would be hinged in the center. Any Thoughts?
Update: I spent some time looking through the script for these doors. I found that it had been written as though you were looking out the door instead of in as in the Product manual. I made some changes and now it looks and lists properly.
