Another texture mapping question.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-11-14 03:51 PM
‎2011-11-14
03:51 PM
MATERIAL "cstmEtchdGlss"
BLOCK 24", 36", .125"
Although the shaders are called "wrapped image" or "wrapped mask" I only want the image on one suffice which for whatever reason is what appears to happen naturally.
The problem is that I want the image to be somewhat anamorphic and can't get the image to start or stop where I want it too.
I've searched through forum all the other info I could about the teve, coor and pgon and have been playing around with the examples in the GDL Technical Standards but cannot seem to grasp what is going on.
I was also curious if there is a way to automatically get the dimensions of an image called into a script and how does one embed images into a script? I tried using the xml converter but I am apparently missing something. I was under the impression that you could create objects out of images somehow.
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-11-16 12:49 PM
‎2011-11-16
12:49 PM
No one?
Can anyone at least confirm wether or not you can manipulate a "texture" imported through LightWorks in this fashion? I've tried the stLaytout to no avail too. Any ideas at all?
The image/texture is being imported with a material definition here:
LWA_transparency = "LWA_TRwmask", LWA_TRwmask_file = "CTP132AInverted.tif", LWA_TRwmask_image = "CTP132AInverted.tif", LWA_TRwmask_softness = 1.00, LWA_TRwmask_scale = 1.0, LWA_TRwmask_aspratio = 0.663109048723898
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-11-17 01:42 PM
‎2011-11-17
01:42 PM
Anyone... anyone... ?
I just want to fit an "anamorphic" image/texture to a simple panel that only shows up in a LightWorks render using either the LWA_TRmask or LWA_TRimage.
DEFINE MATERIAL "cstmEtchdGlss" ... ... ADDITIONAL DATA... LWA_transparency = "LWA_TRwmask", LWA_TRwmask_file = "CTP132AInverted.tif", LWA_TRwmask_image = "CTP132AInverted.tif", LWA_TRwmask_softness = 1, LWA_TRwmask_scale = 1, LWA_TRwmask_aspratio = 1.021551724137931 !LWA_transparency = "LWA_TRwimage", ! LWA_TRwimage_file = "CTP132AInverted.tif", ! LWA_TRwimage_image = "CTP132AInverted.tif", ! LWA_TRwimage_scale = 1, ! LWA_TRwimage_aspratio = 1.021551724137931, ! LWA_TRwimage_softness = 1.00Thanks
