Paul King
Mentor
Bump mapping in surfaces in OpenGL
Perhaps I am losing my mind, but I seem to recall a time in which ArchiCAD could handle 3D display of things like blockwork mortar joints via an alpha channel within a surface texture, allowing the remaining  bricks or blocks to have colour adjustable via colour picker in the surface editor - and that the result worked in the standard OpenGL 3D editing window environment, not just in rendered views.
Am I deluded?  In ArchiCAD 28, How can I have dynamically a colour adjustable blockwork surface appearance in the 3D editing window? (without having to go into photoshop to create every colour permutation via multiple bitmap texture definitions)
Also, as far as I can tell, none of the surfaces in the additional surface catalogue appear to work using bump mapping, though it looks like that is intended?
Operating system used: Windows 11 23H2
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
0 Replies 0
