Achille Pavlidis
Custom frame profile with Curtain Walls
I have created a custom frame profile and saved it as a library part.
Although when I select it on the Curtain wall settings it appears correctly, then when it is placed it has nothing to do.
See attached images. Why is this happening?
Custom profile library partCustom profile library partCustom profile as corner frameCustom profile as corner frameCorner frame not the one selectedCorner frame not the one selected
Operating system used: Mac Apple Silicon 13 Ventura
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
11 Replies 11
cuba
For a curtain wall, you can save a panel as a library element but not a profile ; profiles are based on complex profiles and not library elements. I think you have a complex profile with the same name as the library element displayed as a square by default.
Open this complex profile or create a new one and paste the profile into it.
Normally it will then be displayed correctly.
Apple M1 Max 32 GB
Latest AC
Achille Pavlidis
Bringing this back as it seems that it doesn't seem to work.
I have tried multiple file names and the problem is always the same... the Custom Frame appears correctly in 3D window but it appears only as a square in floor plan...
is there any way to fix this?
cuba
Check your modelviewoptions.  Curtainwall settings can be simplified in MVO
Apple M1 Max 32 GB
Latest AC
Achille Pavlidis
I checked.
I have full view options
cuba
Have you set the 3d detaillevel of the frames to MVO or full?
Apple M1 Max 32 GB
Latest AC
Achille Pavlidis
tried both,
same result
it is OK in 3D but a square on floor plan
cuba
I am out of options 🙂 If you dm me with (a part) of the file, i can have a look.
Apple M1 Max 32 GB
Latest AC
Botonis
Mentor
I have a feeling that you have to enter object's gdl and draw the 2d that you want....
I saw it somewhere and i have to search it.......
cuba
I am using a curtain wall in AC27 with complex profiles and detailled 2d view without gdl...
Apple M1 Max 32 GB
Latest AC
