Archicad 18 USA - but want INT Library?
is there a way I can use the INT library with my version of Archicad (USA 18) ?
I saw the INT library and I want the windows that are in that library.
it has a "basic" window with options that look like they would be helpful.
Or can I switch my Archciad to INT, rather than USA?
Is there a reason not to?
5 Replies 5
Erika Epstein
You should be able to download the INT window from the bim portal via library manager. Much easier as it will include all its required macros.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Oh - Great, thanks, I'll try that.
Can I have BOTH libraries? Or should I only use 1?
Last post: my AC 18 version turned into a smiley face, should have been "18"
Erika Epstein
I wouldn't load both, too many duplicates. Just look through what's available. You could download the INT lib and open that in a new file to see what's available. There are a number of different library parts, but they tend to be from localized versions. The German library is another one. Unlike the INT version, it's in German so could be difficult to use.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
The code for that emoticon is "8"+")", so add a space between the characters [8 )] to avoid that problem.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I was searching for it but I couldn't find the AC18 INT default library, only the AC17 version:
https://bimcomponents.com/LCF/Details/2575
It may be that Graphisoft has not uploaded it yet.
