Archicad 22's stair tool not affected by marquee stretch
Is the Archicad 22's stair tool unaffected when stretching with the marquee tool?
And I don't mean when partially selected, I'm asking about the situation when all the stair's hotspots are within the marquee.
I'm afraid I know the answer, so in that case heads up to everyone who needs to stretch a part of a project with a staircase in it.
2 Replies 2
I don't see any reason why a Stair element should not be moved when it is fully within the Marquee.
I think it is a bug so I will report it to GRAPHISOFT.
Daniel Kovacs
It is indeed a bug. We plan to fix this in an update for ARCHICAD 22 later this year. You will find it in the Release Note as fix #259466.
It was never possible to stretch stairs with the marquee, but you could drag them. As a workaround you can still drag the stair with the marquee, if you draw the marquee box, and press ctrl+D.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
