jshuether
Archicad objects texture orientation
I constantly find Archicad library objects with texture orientations that are incorrect or don't behave as expected. I can make additional rotated textures in my image editor, but this does not work in all instances, so I have to edit the GDL with the COOR command to get the correct texture orientation; however, this is tedious because of (1) extracting libpacks to get to the object that needs editing so they can be saved, and (2) parsing through the GDL to find the actual object that needs editing since objects use multiple CALL commands to other objects that frequently CALL other objects... This is frustrating and it pushes more and more of my modeling to be done in SketchUp. Attached are screen shots. Wood grain running in the wrong direction is very noticeable and makes the 3D images look amateur.
hots of "Hinged Gate" and "Entrance D1".
ArchiCAD 29, Windows 11
0 Replies 0
