Archicad tries to stretch objects when inserting
I am doing a training exercise and when I insert a newly created object archicad tried to draw a scaling type rectangle, and the object gets scaled in two directions to fit this rectangle.
I would just like one click and the object inserted at 1:1.
How can I reset archicad just to insert the object without all the stretching?
See attached screenshot.
Regards,
Michael
2 REPLIES 2
Hi Michael,
In order to achieve that, have a look at the Geometry Method used for inserting objects (you can find that in the Info Box - as shown in the attached image) and choose the first option.
Hope that helps,
Adrian Tudoreanu
Hi Adrian,
thanks, that solved my problem.
Regards,
Michael
