Arrows on doors in elevation/section
I'm using ArchiCAD 10 and wondering if you can turn off the arrow on a sliding door? I can turn them off in plan, but in our Sections/elevations/door schedules the way the doors slide/stack don't always match how it will work once built. We have to use fills to cover them at the moment and I've spent ages trying to figure out how to get them not to show, does anyone know how to turn them off?
Thank you
5 REPLIES 5
Erika Epstein
With the AC10 sliding doors, if you open its Selection Settings and look on the
Parameters Tab
under 3D Representation
There is an on option to have the "opening line in 3D" turned on or off.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks for the reply Erika, but I don't have a 3D Representation tab in Parameters or in DoorBuilder Settings. We're using DWBuilder 35 for AC10 in the Cadimage Library, have you got the same?
Erika Epstein
Sorry, I don't haveThanks for the reply Erika, but I don't have DWBuilder 35 for AC10 in the Cadimage Library, but there are many others on the forum who do.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Emily
Try unchecking the Pivot Line in sections / elevations check box (which I have checked) in the attached screenshot.
HTH
Thanks so much...I thought I'd tried that but just did it and it worked
