Cem
Attributing Standart Doors and Windows as Curtain Wall Distinct Panel
Does anyone know how to define normal windows and doors as distinct curtain wall panel?
Operating system used: Windows 6000 INT Full
David Maudlin
Cem:
What I do is delete the panel, add a Wall the same size as the panel, then put a Door or Window in that Wall. The Wall is not part of the Curtain Wall, so has to be edited separately of there are changes. The advantage is that the Doors and Windows will appear in the regular Door and Window Schedules, which is not the case with Curtain Wall Doors and Windows (panels).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
