Nader Belal
Mentor
BUG: Application query prevents Updating of array parameters
Hi everyone,
In this thread https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=66012&start=10 I have discovered that you apply an "APPLICATION_QUERY" for updating an array parameter (to eliminate an index item) using this code:
n = APPLICATION_QUERY ("PARAMETER_SCRIPT", "FIRSTOCCASION_IN_PROGRESS", _isFirstRun)
The arrays will not update, and thus, the values stored in the original array will always stay, even when you follow the standard indications of Dynamic Array object.
Podolsky
Ace
How I understand this command - when you open object settings, ArchiCAD reads all relevant scripts. First Master script, then 2D or 3D script, then parameter script and UI script.
When you change a value of any parameter or press the button in UI, ArchiCAD reads Parameter script second time.
This request tells you - is it the first run of Parameter script or not. I'm not sure how it can prevent updating anything, only if you use variable _isFirstRun in some conditions.
