Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Bitmap objects in Elevations?
I've just spent about half an hour trying to convert the bitmap people Archicad Library Object into one with Trees.
I wanted to use them for elevations that we do, like this one (trees are PNGs inserted into the elevation).
The object works only in 3D however, elevations and sections display a rectangle.
Anybody found a way to do this?
This would automate work greatly (Tree symbol on plan = tree in elevation)!
1 REPLY 1
leven
Hi Katarzyna,
have you found a solution or a workaround for this problem yet? I totally agree, it would be great to see the bitmap instead of those rectangles in elevation view.
Levi
(Using AC23)
