Bug in a library - Ceiling panel
I have a library from my local manufacturer of building materials. http://www.heluz.cz/files/HELUZ-knihovny-pro-ArchiCad-1_0-2013.zip
There are a ceiling panels with bug. There is strict width of panel: 600, 700, 800, 900, 1000 and 1200 mm. The default width is 1200 mm. This panel works fine. In 3D is like this:
BUT if I change width to another possibility (600, 700, 800, 900 or 1000), it will change 3D representation to this:
It is not a panel anymore. It will add one more panel with 90° as you can see. How can I fix it? I tried to edit this object in Archicad, but there is no possibility to change this effect. I also try Notepad to change scripts, but it does not work too.
Can you be so kind and help me, please???
Thank you.
1 REPLY 1
Have you tried contacting the creator of the library part?
