Cabinet Door Styles - another missing piece in US version.
Just read the last post about corner window issues and though I'd would offer this up. The us version (or at least my current US library) does not have a true flat panel cab door. For some reason, the flat doors have a HUGE bevel all the way around the doors and drawers. I had the idea that maybe they think that since we're so behind the times over here, they figured we would still be using those sweet gloss, beveled doors from the early 90's. So I downloaded the demo international version, installed it, copied the library, and uninstalled. Shazam! - they get an actual flat panel door with square edges. Does not seem that it would have been that hard to give us the option as well....I'm now going to spend some time going through the rest of the library and see what else they get. If anyone has any other library tips to make our lives easier, please pass them along.
Thanks, Matt
5 Replies 5
Laura Yanoviak
The casework objects in the INT Library are far superior to those in the US Library -- it's truely a shame that the US objects have not been brought up to the same level. I would also suggest checking out the GER Library.
Laura Yanoviak
UPDATE: AC11 cabinet objects now have a parameter "gs_bevel" (Edge Bevel On/Off).
Aaron Bourgoin
The link for the INT Libray (v11) is this: http://www.graphisoft.com/ftp/techsupport/downloads/library_updates/LIB11-USA-Win.zip
Tried a similar URL for the GER Library, but it did not work. Does anyone know what the correct one is?
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Aaron,
Unfortunately, this is the link for the US version, not the INT.
Richard
AC26 (since AC6.0), Win10
Aaron Bourgoin
Richard,
Too quick with the 'Submit' button. OOPs. The link for the INT Library (v11) should be this: http://www.graphisoft.com/ftp/techsupport/downloads/library_updates/LIB11-INT-Win.zip
I've looked at my download - its empty. Did anyone else have any luck?
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
