2007-11-23 12:44 AM
2007-11-23 08:46 AM
2007-11-23 09:00 AM
2007-11-23 01:30 PM
2007-11-23 02:15 PM
Basic wrote:The workaround works perfectly, and it applies to images too.
When you call a macro, always use the call keyword and put the name of the macro between quotation marks (e.g., call "m_rail_wired"). Do not create macro calls where the macro name is a parameter to avoid missing macros from archive files. ArchiCAD saves the default macro only into the archive file.
(Workaround: call all parameter values as a macro after the end statement.)
2007-11-23 03:26 PM
2007-11-23 03:53 PM
Fabrizio wrote:Hi Fabrizio,
If I could know in advance these values of course I wouldn't use this issue.
The trouble is I don't know in advance the names of these macros.
2007-11-23 04:00 PM
2007-11-26 01:16 AM
2007-11-26 05:15 AM
Carstene wrote:it's not really cadimage's problem - the fault really lies with the way GS handles the archiving process. there are (as described) some tedious ways around it.
thanks guys for the feedback. So in reality cadimage sells an addon which is for inhouse use only. I guess you won't find this info on their website.
