Call macro from MASTER_GDL and return values
Is it possible to call a macro from a MASTER_GDL.gdl text file?
I’d like to return a string variable from a macro into a MASTER_GDL script. The string variable sets a database key.
I had previously used the plan name request, but that is not possible in 22 & 23.
From what I have tested, a macro call can be included in the MASTER_GDL code without raising an error, but the macro will not be run. Has anyone had any success with it?
*PS Making the project info parameters accessible as GDL Globals would be a great GDL feature.
3 Replies 3
Can anyone from Graphisoft comment on calling a macro from a MASTER_GDL file?
It looks like the MASTER_GDL cannot call a 'macro' in the loaded library, because the MASTER_GDL parts are run before the other library parts are 'loaded'/'made accessible' by the 'list' functionality.
You could try asking over on the GDL Center forum.
GS seems to respond to GDL problems more there than here.
http://gdl.graphisoft.com/forums
Thanks Barry
