Can I create a library from DWG files?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2024-09-21 07:10 PM
Hi!
Is there a way to Smoothly - straight forwardly - without endless workaround .... load 3D DWG library many objects without converging one by one?
I just downloaded all branded appliances (subzero/wolf) that we use in our projects. It's A LOT of files (each product has one 3d dwg). These brands had many different files for different softwares to download, just not for archicad/gdl... hence 3D DWG.
Now when I downloaded & organized everything into appliance folder, my plan was to attach it in Library Manager. But it seems that even though the library is added, it's not showing when I click on object.
I know that archicad can read 3D DWG but I would have to do one by one . My time is worth more than this so it is not even an option to do one by one.
My goal is that when I would since the Appliance folder with 3D DWG, through archicad library manager, that when I would be working in project and search for appliance XY, I could find it, and add it as I work. (The usual).
Please could someone elaborate on how to connect 3D DWG library, or convert it as whole.. or I don't know... basically anything except converting one product by one.
Thank you!
Archicad Solo 26 and 27 (in testing mode)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-10 05:28 AM - last edited on 2024-10-10 05:38 AM by Barry Kelly
Have you tried importing RFA files as GDL.
I've never tried it myself.
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-10-12 07:12 PM
Sure, but I have MANY of them. This is to do one by one - I clarified that one by one is not convenient. If it already can convert the file, it should as well convert several of them at the time or make a library out of it . So that was my question, if there is something better than one by one technique?
