Can i query a buiding material to obtain the vectorial fill of the surface?
i want to query AC about the vectorial fill associated through a surface to a building material.
I can use:
request{2} ("Building_Material_info", vascaMat, "gs_bmat_surface", surface2DIndex)
for the former step but for the latter?
Any help is appreciated.
Bye
1 Solution
I'm not sure ... but does
request{2} ("Material_info", surface2DIndex, "gs_mat_fill_ind", surfaceFillIndex)
return what you want?
Go to post
3 Replies 3
Thanks Karl,
it works, it works
Glad it worked! 🙂
