Can i request inout data from the user interactivly?
I just started GDL.
Its not that hard I better say its very simple if you have coded before.
My main question is.
Can i ask for example the user to interactivly give points or select a line witch i will use.
Is this possible with GDL or one needs to use API coding?
(if this is not possible it would be a great addition to GDL scripting)
Thx for your time
It requires API coding.
Karl
It would be very nice to see it in GDL scripting.
Requestiing points lines and generally data from the user is avaliable in autocad from autolisp days.
It would give gdl much power.
Two simple thinks. Get User input and get an array of selection data.
Imagine the possibilities.
