tsturm
How do I use the 'Hideparameter' command?
Where does one use the command HIDEPARAMETER and how do they?
I am trying to get some parameters to hide based on responses to other parameters.
Has anyone done this?
I have seen parts which use this, but I cannot find them now to see how it is set up.
Thanks
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
4 Replies 4
Aussie John
place your if statement into the parameter script
eg if parameter=xxx then hideparameter "yyy","zzz"
Note the quotation marks
Cheers John
[/size]
tsturm
Can this be tested before using the part?
Can I activate the triggering event to see the parameters hide as a test?
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
An error will get picked-up in a check script, but even if the command is working the parameter will still be visible in the paramaters screen.
Aussie John
also, if you have nested parameters you only need to hide the parent parameter for the others to disappear
Cheers John
[/size]
