2019-09-05 08:03 PM
Solved! Go to Solution.
2019-09-06 03:38 AM
Destyni wrote:
does not allow me to view a 3D figure of the building
custom beam type W24x76. When I attempt to find this type of beam, I am unable to locate it within the design toolbox or from the embedded library.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2019-09-06 03:38 AM
2019-09-06 08:41 PM
2019-09-07 02:56 PM
Destyni wrote:You can use the Attribute Manager to transfer Complex Profiles between ArchiCAD (.pln) files, which is the type of Beam (rather than Object) you show in your screen shot.
As for the beam problem, I added an image to what I am referring to. Beams 1-4 are a different type of beam, thus have been modified to be an object. I thought the W24x76 beam could be found the same way but it isn't.
I am able to place the object beams without issues into a new program; however the beam in the picture (the type not listed as an object), I am unable to find and am uncertain of how to transfer it's information into a new program. Many of the types that this beam can be changed to from within the original file are not possibilities to change into in a new file.
Is there a way to import these already custom made beams into a new file or will I have to attempt creating them myself?
