Change Mullion Size
Hello, I have a 12" thick wall with a window in it. The mullions (circled in red) length is the exact same as the thickness of the wall. However, I want to change the mullions length, but I cant find a way to do so within the windows settings. Any idea how to do this? Thanks
1 REPLY 1
Which window object is it?
