Changing Picture File in Picture Library Object
Hi all,
This probably is a dumb question - but how do you change the Picture File (default is 'Flowers') in the Picture Object in 8.1?
Where are the Picture Files kept and how do you add others. Are jpegs OK?
Thanks
1 REPLY 1
Just type the name of the picture file into the parameter box, click use custom picture first. The picture file needs to be in a loaded library, just like background and texture images. Jpegs are fine, I think any picture supported by archicad should work, but I may be wrong.
