Changing display color
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-07-04 02:32 AM
2018-07-04
02:32 AM
They change to "foggy 1" & "foggy 2" but I would like to make them lighter - more subdued -
is there something in the script I could change? or are they a picture file that I could change?
Thanks Randy
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-04 03:31 AM
2018-07-04
03:31 AM
I can tell you they are images that are embedded in the library part.
I can't tell you if or how you can extract them to edit them.
I know t is a pain, but you could try a % fill (transparent background pen and white hatch pen) to place over the object.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-04 04:29 AM
2018-07-04
04:29 AM
Thanks Barry I have already used masking fills but was hoping for a more permanent solution.
I suspected the images were not accessible.
Randy
Randy
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-04 04:51 AM
2018-07-04
04:51 AM
RandyC wrote:No, they have been saved inside the objects and are not images than can be seen anywhere.
It may be possible to extract them with the LP_XMLConvertor, but I have never tried this.
Then if you did extract the files you would have to modify and convert them back into the object.
Or re-write the object so it could now access the new external image files.
A fair bit of work I would think.
You could possibly add an option to the object (you would need to save as a new object) to add a masking fill that could be switched on/off and the fill type changeable for various shading effects.
I think that would be easier than extracting and modifying the images.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-04 05:19 AM
2018-07-04
05:19 AM
both options seem like a bit of work, I probably wouldn't be sucessful with the first but adding the masking
fills might be the answer -- good idea - thanks,
Randy
Randy
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-06 07:00 PM
2018-07-06
07:00 PM
i tried adding this for the masking fill at the end of the script -- didn't work ,
any thoughts of what i did wrong ?
Randy
!!!!!!!!!!!!!!!!!!!!!!! ADD A MASKING FILL!!!!!!!!!!!!!!!!!!!!!!!!
!! add2 A/B, B/2
if mf then
poly2_b(5), 4, 3, 0, FD, maskpen, BKC,
-A/2, -B/2, 0,
-A/2, B/2, 0,
A/2, B/2, 0,
A/2, -B/2, 0
! DEL 1
endif
Randy
!! add2 A/B, B/2
if mf then
-A/2, -B/2, 0,
-A/2, B/2, 0,
A/2, B/2, 0,
A/2, -B/2, 0
! DEL 1
endif
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-07 08:59 AM
2018-07-07
08:59 AM
POLY2_B{5} needs curly brackets.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
bT Square Peg
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-07 08:33 PM
2018-07-07
08:33 PM
Thanks Vistasp I got it working !!! Good solution and presents better.
Randy
Randy
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-08 05:34 AM
2018-07-08
05:34 AM
That's great!
= v i s t a s p =
bT Square Peg
bT Square Peg
