Changing the width of the text boxes of multiple labels
Hello.
I have a wealth of independent labels, that have the same settings (including text), but are spread all around the drawing.
When I added some text, the text box gained two lines in height and did not change in width, which is not good.
Is there a way in which I can modify the text boxes of all labels, just as I did when I added the text? So that their width is increased and one one line added?
I am in search of something like a Text Wrap...
Thank you.
You can select all labels and turn of the 'Wrap Text' option which will change all labels to one line.
You can turn it back on again but it will not force a second line and I can't see any way to set the same width for all labels.
Seems like you have to manually adjust the width of each label separately.
