Column enclosure (help w/ txt file)
I added fireproof spray to the column enclosure. I can’t seem to get the txt file to work with it. An error keeps popping up in the Parameter Script.
The object also doesn’t properly read the txt file because the distance for the fire proof doesn’t change size per the hour rating.
- This was done in V10
.. fixed
1 Reply 1
Fire Proof Spray Calc =Hours/(1.05 * (W/D Ratio) + 0.61)
for those interested
