Composite Walls with clapboard siding
Is there a place to find composite walls with clapboard siding so that siding shows correctly when sections are cut? This would be mainly for a section detail.
I don't think that there is anything integral to AC that will create clapboard profiles. I have been using composites to create walls with a core, drywall, and sheathing, then using cadimage accessories to add a clapboard wall accessory. This works well and adds the right profile/dimensions for sections and elevations.
Unfortunately, it isn't free and I don't think it works with educational versions if that's what you're using...
edit - BTW, I graduated from the Umass interior design/architecture program
