Learn more
Achille Pavlidis
Concealed / hidden door object
I'm trying to find a concealed / hidden door object, but can't find one. Does anyone know if there is one?
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
2 Replies 2
Miha_M
For 3D representation you could use the default library door, you'd need to play with the reveal settings to get the desired result. Here an example I made with a few clicks.
I sadly don't have any solution if you are looking for an element with dedicated BIM values and accurate 2D details.
| Archicad 4.5 - 29
JanisL
but can you get it like that from both side? I think this is the main problem. To get the relaeve so, that it is hidden from both sides.
