Corner Window
Why do I only have the option of an empty corner window? Can't I use the same window as elsewhere in the drawing, and just make them corner windows? AC11.
thanks
4 REPLIES 4
Djordje
thanks
Are you using the window tool or the corner window tool?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Corner Window tool. I would like to use a 4' x 4" fixed window with 4' x 2' operable transom as a corner window. the corner conditions vary, but all are 90 degrees or less. When i select the corner window tool, i cant seem to manipulate the window other than the color of the fill. Any help would be greatly appreciated.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
What library are you using? I guess, you don't have any Corner Window compatible windows in your active library. I don't remember any issue which would keep you from using a proper CW object in the CW tool.
Regs,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
I'm using the standard AC11 Library. Is there anywhere i can dowload a more extensive corner window library?
