Creating Custom GDL Windows
Does anyone know how to create and save a custom GDL window. I have already created the window and saved it as a .gsm and as a window. The problem i have is when i place the window in a wall, the window comes in horizontal instead of vertical like all other windows. Does this have anything to do with the position the assembly is in when i initially save it as a .gsm file?
10 Replies 10
Indeed, you'll need to position your camera in Axonometry View to get a top view of your assembly, then save as... Have a look at Interactive Training Modules > Building Objects Creation : http://www.graphisoft.com/products/archicad/training_guides/
Good luck
Or AC 12 Reference Guide pages 321-322
thanks for the response. Yeah, i did go into the parallel projections settings dialog, and clicked on the top view camera position, then did the save. I also did the elevation view, still the same result though.
Erika Epstein
When you save it from the 3D window as a library part, are you choosing the WINDOW as the type of object?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
In fact, you don't need the 'top view camera position' icon... Try Side View and turn the camera above : open the 3D window again and you should see the top projection of your assembly . Then save as...
yeah, i am saving it as a window. I also did try the 'side view' in the projections settings, not sure what you mean by 'turn the camera above : open the 3D window again and you should see the top projection of your assembly'. Do you just mean to rotate the view in the 3d window by using orbit to get a plan view of the assembly again?
thanks
Erika Epstein
Try this
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I just tried that method, still same result, comes in sideways. I don't think you can rotate the window once its in the wall, to make it upright, or can you?
Here is a look at what is happening.
Erika Epstein
K,
Start over.
follow the trainging guide
custom window creation
Add your OS and Archicad version to your signature.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
