Custom Panell
Hi! Why when I try to save a custom leaf for a door, after I choose the type the dialog box show duplicate types and some time the panel just created it didn't show up in the avelible custom panel or leaf.
Thank for the help.
See attachment
Happy modeling!
3 Replies 3
David Maudlin
My guess is that you have duplicate or multiple libraries loaded, the custom components are in the Custom Object Macros folder in the ArchiCAD Library. If you have a library from an earlier version loaded, then selecting that component may not work. Check your Library Manager.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
vfrontiers
Also, make sure you're not creating a custom KNOB and a custom DOOR PANEL with the same name....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Thank you so much, for the replay I will check Monday, and I let you know.
