TomWaltz
Cutting Door/Window openings in an Object?
Is there any way to cut/call a door or window in an Object?
We are using a type of pre-fab wall system, that I was going to try to create an object that has all the joints and contruction in it. I had considered making the plans and elevations from this object instead of composite walls with 2D linework added for sections.
Our big hold-up is that I cannot figure out a way to cut window openings in the object.
I'm guessing this is not possible.
Tom Waltz
6 Replies 6
Tom,
There is a way... sort of.
Subtract a piece of wall from the object and place the window in it.
A little clunky but it should work.
TomWaltz
it would work.... I was just hoping to be able to get the object to detect the window, then frame around it....
Tom Waltz
SeaGeoff
Ace
take a look at orbit solutions precast panel
http://www.orbitsolutions.com.au/
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
TomWaltz
Geoff
that looks like it does the FORM of the panel, but not actually create any framing/construction inside it.
Is that correct?
Tom Waltz
SeaGeoff
Ace
As far as I know that is correct. I’ll know more next week as I’m going to demo orbit’s stuff for the users group.
Whoa dudes, I just got my third Monopoly house
If you are programming the object - then why not programme the window/door too? Maybe you could borrow the script from a Archicad window/door and past it in. But otherwise window/doors will only place into walls I am afraid.
