D Marker 21 Polygon Shape rotation problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-08-14
01:03 AM
2023-05-24
10:43 AM
Rubia Torres
2018-08-14
01:03 AM
Can this be easily fixed with a couple lines of GDL or does anyone know of a marker/label that can be as the list below:
- oval polygon shape
- perpendicular to the door
- reads the hotlink and element ID (bonus: can include custom/auto text so that we can have D.#HotlinkID.#ElementID without spaces; we want to avoid naming the Master ID of modules using D.001. as the nomenclature, 001 being Unit/Room number)
these questions are a bit ranty.. apologies for the tone but I have spent too much time messing with labels.
[1]why can't we use auto text with labels eg the property label in the custom text box (need hotlink and element ID) ?
[2]why can't the auto text frame be selected from a drop down like some of the other labels eg oval ?
[3]why are the three lines of the property label automatically separated by a space ?
[4]why aren't there more text lines of the property label ?
AC24
2 x Xeon E5-2667 v2 (16c/32t @ 3.3-4.0 GHz)
64Gb RAM(ECC) Quad channel 1333Ghz (next upgrade 1866Ghz)
Nvidia GeForce GTX 1080 Ti 11Gb
500Gb 840PRO SSD, 3 TB HDD (next upgrade PCIe NVMe SSD)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-08-14 01:19 AM
2018-08-14
01:19 AM
This is also what happens when i select horizontal on the text. The polygon does not follow the rotation
AC24
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-04 12:59 PM
2018-10-04
12:59 PM
Hello davidstonearchicad21,
Though there is no way to achieve this with the Built-in Door/Window Markers, you can get quite close with Labels, or even create your own custom Label through GDL coding that does exactly what you are looking for.
I have attached a picture of 2 ways I could achieve a similar result:
- On the left I used a simple Autotext Label with the Hotlink and Element ID displayed, and added a textbox frame on it. This can be aligned, placed and customized quite easily, but it can only have rectangular frames.
- On the right I used a Property Label. For this Label you can select the same Values and it can also have an oval frame, but it's a bit harder to align it properly (because it is meant to have a handle and a bubble).
In both cases you have to set the alignment to custom and the angle to 90° (relative), but in ARCHICAD 22 you also have the option to make them Perpendicular automatically. I hope you can get along with these options.
Regards,
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
GRAPHISOFT
