JGoode
Is it possible to define Pens in GDL?
ArchiCAD 27
Windows 10
1 Solution
JGoode
Hello,
Just to revisit this, how can I convert an RGB value into Graphisoft's 0-1 system?
Thanks
ArchiCAD 27
Windows 10
Go to post
7 Replies 7
runxel
No.
You can only request a similar pen to a RGB color:
REQUEST ("PEN_OF_RGB", colorInRGB, pen)
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
JGoode
runxel wrote:
No.
Do you have any example script of this? Thanks
ArchiCAD 27
Windows 10
runxel
rr = REQUEST("PEN_OF_RGB", "0 1 0.2", _greenishpen)
!!! color range 0 to 1  //  WTF GS?
pen _greenishpen
set line_type   1
line2           0,0,5,0
Whoever did the 0 to 1 thing was clearly effing around.
It is 0-1 in all MacOS at least in early versions 😉
anyway it is more accurate BTW: 256 points vs _the_accuracy_You_need 😉
Not that I like it...and in any script I use X/255 to get the GDL needed value while any soft would rather give 0..255.
Best Regards,
Piotr
runxel
Best Regards,
Piotr
I know Piotr, but the accuracy is not the point.
It is about consistence and usability.
The implemented way is just total madness! 😉 It's like cooking by receipt with imperial units but living in Europe.
JGoode
Hello,
Thanks
ArchiCAD 27
Windows 10
Jochen Suehlo
0 * 255 = 0 (black)
1 * 255 = 255 (white)
0 / 255 = 0
255/255 = 1
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
