Is it possible to define Pens in GDL?
JGoode
ArchiCAD 23
Windows 10
JGoode
Just to revisit this, how can I convert an RGB value into Graphisoft's 0-1 system?
Thanks
ArchiCAD 23
Windows 10
7 REPLIES 7
runxel
Hero
No.
You can only request a similar pen to a RGB color:
REQUEST ("PEN_OF_RGB", colorInRGB, pen)
JGoode
runxel wrote:
No.
Do you have any example script of this? Thanks
ArchiCAD 23
Windows 10
runxel
Hero
rr = REQUEST("PEN_OF_RGB", "0 1 0.2", _greenishpen)
!!! color range 0 to 1  //  WTF GS?
pen _greenishpen
set line_type   1
line2           0,0,5,0
Whoever did the 0 to 1 thing was clearly effing around.
It is 0-1 in all MacOS at least in early versions 😉
anyway it is more accurate BTW: 256 points vs _the_accuracy_You_need 😉
Not that I like it...and in any script I use X/255 to get the GDL needed value while any soft would rather give 0..255.
Best Regards,
Piotr
runxel
Hero
Best Regards,
Piotr
I know Piotr, but the accuracy is not the point.
It is about consistence and usability.
The implemented way is just total madness! 😉 It's like cooking by receipt with imperial units but living in Europe.
JGoode
Thanks
ArchiCAD 23
Windows 10
Jochen Suehlo
0 * 255 = 0 (black)
1 * 255 = 255 (white)
0 / 255 = 0
255/255 = 1
Jochen Suehlo . AC12-27 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
