davidstonearchicad21
D Marker 21 Polygon Shape rotation problem
I'm trying to create a simple door marker in a HL module that displays the Hotlink and Element ID of the intra unit doors with an oval marker polygon shape that is perpendicular to the door. I can achieve 90% of that. The last 10% is frustrating. The oval will not rotate with the text, results below.
Can this be easily fixed with a couple lines of GDL or does anyone know of a marker/label that can be as the list below:
  • oval polygon shape
  • perpendicular to the door
  • reads the hotlink and element ID (bonus: can include custom/auto text so that we can have D.#HotlinkID.#ElementID without spaces; we want to avoid naming the Master ID of modules using D.001. as the nomenclature, 001 being Unit/Room number)
these questions are a bit ranty.. apologies for the tone but I have spent too much time messing with labels.
[1]why can't we use auto text with labels eg the property label in the custom text box (need hotlink and element ID) ?
[2]why can't the auto text frame be selected from a drop down like some of the other labels eg oval ?
[3]why are the three lines of the property label automatically separated by a space ?
[4]why aren't there more text lines of the property label ?
AC24
2 x Xeon E5-2667 v2 (16c/32t @ 3.3-4.0 GHz)
64Gb RAM(ECC) Quad channel 1333Ghz (next upgrade 1866Ghz)
Nvidia GeForce GTX 1080 Ti 11Gb
500Gb 840PRO SSD, 3 TB HDD (next upgrade PCIe NVMe SSD)
This is also what happens when i select horizontal on the text. The polygon does not follow the rotation
AC24
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello davidstonearchicad21,
Though there is no way to achieve this with the Built-in Door/Window Markers, you can get quite close with Labels, or even create your own custom Label through GDL coding that does exactly what you are looking for.
I have attached a picture of 2 ways I could achieve a similar result:
- On the left I used a simple Autotext Label with the Hotlink and Element ID displayed, and added a textbox frame on it. This can be aligned, placed and customized quite easily, but it can only have rectangular frames.
- On the right I used a Property Label. For this Label you can select the same Values and it can also have an oval frame, but it's a bit harder to align it properly (because it is meant to have a handle and a bubble).
In both cases you have to set the alignment to custom and the angle to 90° (relative), but in ARCHICAD 22 you also have the option to make them Perpendicular automatically. I hope you can get along with these options.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
