‎2008-04-11 04:02 PM
‎2008-04-11 05:18 PM
‎2008-04-12 04:18 AM
‎2008-04-12 11:28 AM
vistasp wrote:Hi Vistasp,
it seems that four out of the six D Openings (Arch, SemiArch, Horseshoe and Ogee-Centered) are not correctly seen in elevation when viewed from one side but okay from the opposite side!Gothic and Saracenic, on the other hand show up correctly whichever way you look at them.
‎2008-04-12 12:04 PM
adytc wrote:So it's not just me then... Thanks Adrian, I was beginning to wonder.
I'm experiencing the same problem here. I'm using INT version of the library, with the latest update.
‎2008-04-12 02:23 PM
‎2008-04-13 05:24 AM
Braza wrote:Hey thanks Paulo, not just for the updated objects but also for explaining what exactly was wrong with them. Will try them out once the weekend is over.
The problem seems to be the status code for the wallniches.
I've just changed "2+16" to "1+2+8+16+32+64+128".
It seems ok now...
‎2008-04-15 10:44 AM
vistasp wrote:I always turn on all the status when there is something wrong in a code...
...I thought "1+2+8+16+32+64+128" looked a bit extreme. Experimented a bit and found that "2+8+16" works equally well.
‎2008-04-17 12:12 PM
Braza wrote:Paulo you're absolutely right! The problem lay in the mask codes. I
I can see some weird mask codes like 15+49 or something...
‎2008-04-17 12:57 PM
