Different Plan Views
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-07-05
01:24 PM
‎2023-05-26
11:22 AM
Rubia Torres
I'm currently working a residential project that is split into three pavilions oriented in 3 different directions. Basically I would like to be able to isolate each of the pavilions in plan and rotate them so that they are straight (not on the angle) for ease of documentation as trying to dimension all three on the one page will get very hectic. Is there a way that I can rotate each of the pavilions then save the plan view as a view setting and still be able to revert back to the original orientation? I have tried dropping a detail marker over each pavilion and manually updating the information but i loose all my 3d information and my door and windows turn to lines. Hopefully all that makes sense.
Any help would be much appreciated.
Kind Regards
Tommy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-05 02:37 PM
Pleas add your specs to your profile signature.
In 14 there is a rotated orientation - page 278 of the user guide.
Personally I would model each pavillion (square) in its own PLN file and then hotlink those into a fourth master PLN at the correct rotation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-07 05:59 AM
This hotlink method looks like the way to go. I will look into it.
Thank you very much for your help.
Tommy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-07 06:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-07 06:55 AM
When you place the view on the layout you can crop off what you don't wnat to see.
Then orient for another pavillion and save that as a view.
Place on layout and crop.
Repeat for the third pavillion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-07 07:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-07 07:09 AM
You will need to use layers to turn on/off what you need.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-07-07 07:10 AM
Tommy
