Display order in sections/elevation
Hi, I am trying to figure out how to control (in the GDL script) which elements are displayed first ("on top") in views of the object created by building sections.
Specifically I am finding that some LIN_ are covered by other pieces even if the LIN_ is the closest piece of the object in the view.
In attached file the horizontal black line is actually closest but for some reason is placed behind the vertical grey lines that are actually farther away...?
0 REPLIES 0
