Door Does Not Show in Section
Please refer to attachment. I have a door that shows in 3D and in elevation but not in section. I can "see" it highlighted in green in section if I select it but cannot figure our how to get it to show properly. Selecting "Move to Front" does not effect it.
Just prior to it not showing in section, I had used the axe tool to split the thickened slab edge twice below the door so that I could change the slab edge piece left between the two splits to a slab edge profile that is appropriate for under a door (i.e., wood blocking etc.).
Thanks in advance for any assistance.
1 REPLY 1
David Maudlin
Michael:
Your image is not showing, you may need to upload again.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
