Door Hardware
How we can add door hardware to the library from any of the sites where they are already modeled and in gdl format without having to convert them into morph.
1 Reply 1
Lingwisyer
Guru
If their sub type is assigned as a door, or relevant part of a door, they should turn up under the custom component sections of the default door objects.
ie. Assign it as a "Custom Door Leaf" and it will appear under Door Leaf Type... = > Custom Door Leaf.
Assign it as a "Custom Handle" and it will appear under Door Leaf Type... = > Handle & Kick Board... => Handle => Custom
If it is assigned as a door itself, rather than a component of a door, it should just appear in your library under the relevant file structure that it is saved in.
Ling.
