GeorgieB82
Door Leaf - Archicad 22
Hi All,
I've just upgraded to Archicad 22 (Solo) and I am having a problem with doors. It doesn't matter what leaf style I choose it only shows as a plain door.
Is anyone else having this problem?
George
AC25 UK Solo
Windows 10 Pro, Intel Core i7-4790, 16GB RAM, NVIDIA Quadro K600
1 Solution
By default, archicad 22 model view option for detail level of door, windows and skylight symbol is set to "simplified",
you need to change it to "FULL"
Go to post
4 Replies 4
I am not very familiar with the Graphisoft doors and windows (I don't use them), but check in the door settings to see if there is an option to display the 3D in "Simple" mode.
If so you will want to swap to "Detailed".
If it is not an option in the door itself, then have a look in the Model View Options for the same thing.
Guru
It would appear to me that by default, the MVO is set to display doors and windows as "Simple".
Ling.
GeorgieB82
Thank you!
AC25 UK Solo
