Door Problem
When I go to place a double door (a D2 or in this case a D2 Segmented Transom) the door panel width always changes on me. For example, I place the door with the default width, let's say 5'-0". Let's say I go to enlarge the door to a 6'-0" width, this is where the problem arises. One panel stays at 2'-6" wide and the other goes to 3'-6" wide. I know under "Elevation and Opening" you can change the width to match (you have to manually do the math for it and type it in), but in this specific case that is grayed out and I cannot do anything. Shouldn't the door panels automatically be the same width anyway? What is happening in this specific case that I cannot change the width?
7 REPLIES 7
72 Views and no answer? Can anyone replicate this issue? Does it work for anyone? Is this a bug? Should I complain to Graphisoft? Am I asking too many questions? Is anyone annoyed? Is anyone listening? My avatar is lonely....
Maybe a screenshot will help?
Architects tend to see problems visually.
Maybe I just stumped everyone
Erika Epstein
It's a known problem and has been discussed in earlier posts.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
maybe if you ask into the correct discussion (like "working in AC")
Stress Co_
Look in "Door Panel" Parameters for "Panel Division Type".
Check: Proportional
and a screen shot for us Architects
Marc Corney, Architect
Red Canoe Architecture, P. A.
Erika Epstein
Check: Proportional
Unfortunately, for the D2 Segmented Transom , this option is not available
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
