Door Schedules - No Hand Parameter?
In 8.0, the door objects had a schedule parameter that told you whether it was a Left or Right handed door. Unfortunately, it always filled the schedules with the letter 'L'. We added our own parameter to fix this problem.
But now we are working in 8.1 R2 so I thought I would see if the hand parameter worked. Unfortunately, I can't even find a built-in hand parameter. Am I missing something, or does it have some funky name that wasn't translated from Hungarian correctly?
3 Replies 3
tsturm
Can AC determine the Handing of the door automatically?
I would like AC to do this for me as part of the door schedule.
Would I still be able to place doors with the center tool? Would I have to use the end point and three clicks?
How did the handing work in V7.0? Never used schedules in 7.0
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
__archiben
WIDO_ORIENTATION
i think that this is the global variable required to return the handing? i'm not the GDL guru in the office, but we've just recently used it to produce our own doors for just this information on the schedule.
i'll dig around and try and find out what we did . . .
HTH
~/archiben
b e n _ f r o s t
Djordje
The opening direction? Yes, when you place it, it knows.
Choose the insertion method in the Info box; you can do it even after you clicked the insertion point.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
